Eu tenho um Ford Transit 2.5 TD lavar o motor e agora muita fumaça branca sai para o escapamento e ele não acelera, mudei a bomba de injeção e continuo fazendo a mesma coisa que posso fazer mais?
If your car has made white smoke, it is most likely that it is water in the fuel because injection advance cannot be because the pump you already changed and point it can not be because the fault was already there before changing the pump I do not think that the injectors have been danced you can put a galonera with oil and hoses as if it were the tank purges the pump well and starts if the problem is how I said water
