Olá, bom dia a todos que esperam que eles encontrem ótimas saudações coordiais.
Well once again I turn to you to support me since the following message came out, "Selector 4 Service" I tell you that my truck is a Jeep Gran Cherokee 1997 limit 4 x 2 6 cylinders, it has as a 1 month that this message came out and two weeks ago I get in the next fault, walking the repeating truck does not accelerate as if the accelerator is disconnected, you will not pull it You carry and repeat again without any problem, now I manage that but I have to turn it off to accelerate again, the mechanic told me that the crankshaft position sensor, since it did that to me being in my daughter's school and move the sensor and the truck stabilized, since I found that when it slows it as it loses pressure as if it wanted to go out, it I moved the crankshaft sensor and the truck on the way as if nothing told me that I was wrong, and 4 days and today in the morning I spend the same thing you accelerate at 90 km E repetiu o acelerador não respostas mais que você precisa para salvá -lo para pegar o caminhão e ligar novamente e pronto. Alguém saberá o que posso fazer. obrigado.
