For giving an opinion, I suppose the alignment of the motor steering wheel both the alabeo and the centered, if this is fine, I already wonder if being the same engine but with different weight in one (motor steering wheel) and another (crown and flexible dish), if there will be no weight difference in the crankshaft-shay-s Disco springs ending up breaking ... or that there is some unbalanced of the set due to the weight of the steering wheel of one engine, placed on another ... Eles são apenas conjecturas, pode ter algum dado que saberá se existe essa variante entre o manual e o 1zz automático ... ??? Saudações!!
