Pesquise no MDM
Boletim
Explorer 98 4.0 V6 Inundação de gasolina O motor
  • Autor do assunto
  • Pensionista fresco
Avançar
9 anos 10 meses antes #49928 por Manual-Mecanica
Explorer 98 4.0 V6 Inundo de Gasolina O motor publicado pela Manual-Mecanica
That such colleagues, it turns out that my explorer had blocked the alarm and since I have no control disconnects and it does not suiche, when I pass the suiche it sounds something in the camarin as if the pump did not pay and it turns out that I fill the motor x inside gasoline, and I have not been able to turn on because when that sounds in the camarin, I think the pump is direct THANK YOU THE CONTRIBUTION Q CAN GIVE
