Good afternoon, I request your help to correct a failure in a 2006 Ford Mondeo, the problem is as follows: the alternator's regulator changed because I did not put a charge to the battery, when I took it to the technic And he told me that the regular no longer Serbia, that he had a bad connection in the cables that go for the regulator and arrange them, I personally change the regulator this time, I put it and started putting a load very well, but soon after I stopped doing O que ele notou é que, quando ele acendeu as luzes, eles pareciam muito bem claros e normais, mas quando fiz as alterações do casualt e a bateria caiu, acho que a falha pode estar no sistema de luz, mas não sei como verificar para encontrar o curto.
Se alguém puder me ajudar, ficarei muito grato.
Marino Rossainz.
