The turbos can be repaired, of course, but to make it yourself, it will depend on the knowledge you have on the subject, where buying the kits will depend on where you are, that is, Spain, Chile, Mexico etc. And the information will be provided by the people of your paiz, now the turbo is not very complicated in its structure but diagnosing the fault you want to cost a little, usually the Turvos are changed withdrawal and check the vasto as well as the Haspas, Mas, na ocasião, o reparo é mais caro do que comprar um novo. Foi o que aconteceu com o seu turbo, o eixo é cortado à medida que a potência geralmente acontece ou diminui, os rolamentos somam ou o quê?
