Temperature increase
13 years 2 months before - 13 years 2 months before #34064 by manual-mecanica
Temperature increase published by manual-mecanica
Respected professionals, I was presented with a problem in my Ford Explorer car of the year 97, when I turn on the air conditioning, the temperature indicator is raised more than normal, I already changed the fan clutch and continues to increase the temperature. Any comment will be well received and of new thank you very much and move on are of great help and importance for all of us ... Thank you. --..--
Latest edition: 13 years 2 months before by .
13 years 2 months before #34070 by manual-mecanica
MANUAL-MECHANIC APPLICATION ON THE RE: temperature increase
Rafael reviews first that the thermostat is opening at the temperature that corresponds and enough for good circulation, after the radiator ducts are uncovered and finally there is no dirt between the radiator and the air conditioner
13 years 2 months before #34074 by manual-mecanica
If after checking everything Daniel has told you, he keeps heating the water pump and checks that the axis has not been broken once with a Ford Ranger and the truth you go crazy a greeting a greeting
13 years 2 months before #34081 by manual-mecanica
With respect to himself .. How much is the standard in the temperature meter, I commented my trucks is a Ford Explorer Model 93 and for a few days to start the temperature I would say to 35% this to say in past months does not appear it is not possible to mention that the radiator is a year that changed it for a new one would appreciate any comment and observation in this regard.
13 years 1 month before #34082 by manual-mecanica
Hello, I hope it is not serious. In any case, not all vehicles work at the same temperature, and the fundamental thing is to check the greatest amount of possibilities to determine where the failure is. Do not part of the radiator for more to be new controls that the water circulates through all the ducts. Surely he has the electro bulb, if you can control that he opens and closes at his corresponding temperature. Look that the electro garment at the corresponding speed. On the other hand, check that the water system does not have oil remains and that it works with the corresponding level. It can also raise the engine temperature an oil already in poor condition or a low level of it, do not forget that in addition to lubricating it is the one that carries the temperatures of the friction out. These are some things to keep in mind that you can do quietly I hope I have helped you a little. My greetings, good luck.
