Temperature increase
13 years 1 month before #34811 by manual-mecanica
MANUAL-MECHANIC APPLICATION ON THE RE: temperature increase
I already did the radiator but follow the clear problem is less if it served a lot but even when I turn the A/C, it raises the temperature a little more than normal, friends I need your best comments, thanks.
13 years 1 month before #34912 by manual-mecanica
I believe that it is normal that the temperature rises a little more, since the engine works more forced with the year it is so that fuel consumption rises when used, what would have to find out what is the maximum work temperature of that engine
13 years 1 month before #34923 by manual-mecanica
You are very right the truth is that the first thing is to leave for what the normal temperature should be and with the A/C thanks for the help you can give me. But I am sure that it is out of the normal increase. thank you. friends-
