urgent
12 years 8 months before #37952 by manual-mecanica
Manual-Mecanica response on the urgent
If the water is overwhelmed by the entrance of the water storage, the thermostat may be locked and do not let the water pass to the engine.
12 years 8 months before #37954 by manual-mecanica
If the water throws you, or the hoses are very swelling, it is certain that it has a leak in the cylinder lid joint in that case will have to fry, the lid changed joints and screws, if it does not throw the water and heats up you only the thermostat. And it has rason Hugo you have to purge it very good luck
12 years 8 months before #37960 by manual-mecanica
Hello, the water does not overflow with the deposit and the hoses are normal, the only thing when I turn on the heating seems to pass water with air, how do I purge the water I put water and quite cooling?
12 years 8 months before #37968 by manual-mecanica
Hello, 1 step, look that the radiator at the top of the companion side has to have a purge screw which you have to loosen it so that the air comes out while making water 2 step it has to have another pothoguer in the hose that goes to the heating radiator, you put it in motion and loosen the spotter spot that comes out all the air And ready.
12 years 8 months before #37990 by manual-mecanica
Hello ok that we discard the oil and all well purged I opened the heating so that all the air comes out if you can control that no hose is above the water storage we lack the pump and the thermostat I would tell you that you fix if you can and you have it by hand touches the hose if one is hot and the other does not, at the time that the temperature reaches the usual normality of your car. Radiator thermostat touches the hose and thermostat if the temperature has a difference is the thermostat Another detail The electro turns on when heating?
You have to control all the details those
You have the photo of the thermostat is the aluminum gray piece and the pump is the black piece for me if you assure me that the radiator is clean is one of these two things as the last option may be the Board but very little and that it passes only comprehecious but not lifting so much temperature or so fast
Proba and let us successful and greetings
