XTRAIL PROBLEM 2006 GASOLINE
11 years 5 months before #44961 by manual-mecanica
Problem Xtrail 2006 Gasoline published by Manual-Mecanica
Hello I need help because it does not maintain the minimum and the acceleration oscillates
11 years 5 months before #44962 by manual-mecanica
Manual-Mecanica Response on the subject XTrail 2006 Gasoline
Hello everyone, Lsánchez25, the witness of Averias or Chek Engine is on with the engine working? greetings.
11 years 5 months before #44966 by manual-mecanica
Hello, thank you for answering, you are not working, the issue is that you changed your head for overheating, and now once everything is armed, the accelerator is not stabilized.
It worked well for a few days and then appeared with this problem.
11 years 5 months before #44967 by manual-mecanica
Hello everyone, Lsánchez25, who is not working? I didn't understand that part?
11 years 5 months before #44992 by manual-mecanica
Check's light does not locate if the engine turns on
