Rear wheel problem
11 years 5 months before #45119 by manual-mecanica
MANUAL-MANICA TENSEWORK PROBLEM PUBLISHED
Well I hope they help me since I am a little worried, the matter is that my Land Cruiser has 52000 km and I have noticed that the rear wheels are spent inside it leads it to the mechanic of the consequential and told me that it was because I drove with a lot And if it is normal or not.
11 years 5 months before #45120 by manual-mecanica
Manual-Mecanica response on the problem with the rear wheels
Hello Ronald_Mago, an excessive angle of falling the rear wheels can be the problem, you must first check all the rubber rubber of the rear suspension, as well as fixations in the rear arms before taking it to make a check of the alignment and parallel levels, because without means it is difficult to do this well. Also assess if you load it a lot, the suspension can be ceded, check the height under a helmet that is said. Greetings!!
11 years 5 months before #45121 by manual-mecanica
Do not ovidate first of all, check if you have the bearings of the rear bushings, if so, adjust these.
11 years 5 months before - 11 years 5 months before #45184 by manual-mecanica
The truth is that I always travel lightly
Another thing as I could see if the rear bush bearings have a game?
Last edition: 11 years 5 months before by .
11 years 5 months before #45185 by manual-mecanica
Ascert that the wheel bolts are pressed, lift the rear and pushing the wheel at its highest part (moving to Detro and towards you), if you have a game, you will notice ... you should not move, I hope I explained to me. Greetings!!
