Ismael53 I did what you suggest, lift the rear wheels with the cat and push the wheel to see if you have a game but nothing is firmer, I must also say that the stick is fixed.
Hi Ronald ", starting from the fact that the bearings are not cleared, you must continue to look from the bushing to the suspension (brackets, bloodstblock of rubber spent ...) slack in shock absorbers, see the status of the supports of these ... you must look and help you a small lever to go" moving "suspension elements that can vary the position of the wheel. folded ... you are already telling us.
