Motorcycle manuals
15 years 8 months before #10031 by manual-mecanica
Manual-Mecanica Response on the Re: Motorcycle Manuals
I have not disassembled the engine and when I was to mark the distribution chain, the little one fell and knew it the move. : HUH:
The theme has been closed.
15 years 8 months before #10035 by manual-mecanica
Hello, I need the Yamaha Warrior 350 manual if I had it a favor greetings thanks
15 years 8 months before #10039 by manual-mecanica
Hello, would I know if you have the Honda Scoopy Sh 75 manual? It is from 1991 + or -
thanks
15 years 8 months before #10046 by manual-mecanica
Hello Malmotero,
at the moment I have a dominating deep (NX 649cc, 4 times, mono cylinder, 4 valves, automatic decompressor) of which I have manual by the way, if you find out and interest someone would scan it.
Well mine is a mechanical problem. The motorcycle is fine but the engine sounds a lot, either as worn bearings or a lot of game between shirt, possible wear of hoops, or piston bearing, or rod head.
I have two engines and the truth is that I have found the noise in both.
Do you know or have heard if it is frequent in these engines? Do you know what it can be due?
I intend to make the most complete maintenance of the engine that I have disassembled, do you have any recommendation? Any Honda workshop that you recommend to buy pieces and have some advice, Are Madrid?
Very sincere thanks for your generosity and your help with the foreros.
15 years 8 months before #10058 by manual-mecanica
Thank you very much:
your information served me, anyway the problem was in one of the NAFTA ducts, so the faya that made me, with a fog battery.
: Woohoo:
