Oil in the escape
15 years 6 months before #10824 by manual-mecanica
Manual-Mecanica Response on the Re: Oil in the exhaust
Friend before disarming, look very well if what comes out by the exhaust is oil because it can be fuel without burning should check the moisture comes out the possibility that the injectors are not polishing can also happen that this one aberced to revase the injectors I hope you can help you
15 years 6 months before #10825 by manual-mecanica
Hello friend, look good, if what comes out for the escape is oil, because it can be fuel without burning. Check that cylinder comes out of moisture because they can be injectors that do not polber and can aber 1 a veiled and there is no splage in that cylinder and spullen the fuel without burn. I want this to be useful
15 years 6 months before #10903 by manual-mecanica
Hello everyone, my engine is a 2703 Ford Industrial Diesel engine is mounted on Claysoond 1530 rice harvesters in boats is used as a stationary engine in irrigation facilities.
6 cylinders online 6000 cc, I don't know its exact hobble but it must be in about 120 HP, it does not have a 104.6 mm piston diameter.
They are not the injectors because I mount those of another similar engine that I am here and it continues to pass oil.
Bring two compression and one oil rings.
15 years 6 months before #10907 by manual-mecanica
Greetings if you are throwing oil in liquid state by the exhaust tube I suppose that I will throw a lot of white smoke. Otherwise it is not oil what you say that it will be diesel of injector springs failure that open to Choro
15 years 6 months before #10908 by manual-mecanica
Hello,
do not take me badly, but quiiza have mounted the pistons erroneously, I mean that it is not shown to the indicated side. Then it turns to an oil pump. Is the engine also burning oil, does it mean a blue fumarola? How is the compression and have a compression leakage test? With this you can define that cylinder (s) is where the problem originates. Greetings
