Aid for Fiat Palio Adventure truck
16 years 4 months before #7017 by manual-mecanica
Manual-Mecanica Answer on the Re: Help for Fiat Palio Adventure truck
Check the steps engine well because they fail especially if it is dirty and controls the operation of the Lambda probe a hug.
16 years 4 months before #7029 by manual-mecanica
Let's see gentlemen, but with another car a similar fault and it was the MAF or the air flow sensor if they can always try another code, clean the admission pressure sensor that sometimes is filled with impurities and does not read this sensor well in the admission collector,- Greetings Ah Read the values ​​of the Lambda tube with the hot engine to see what values ​​must always be and -1 greetings Alf.-
13 years 6 months before #29280 by manual-mecanica
Hello everyone, the electronic pariposa tine? In many Argentine models the potentiometer of the butterfly body fails and generates a fault similar to the one named if so change the electronic part of the butterfly body greetings
12 years 5 months before #39688 by manual-mecanica
It is a sensor if I do not I think is that of the camshaft
