Urgent Help Kia Sportage 2000
14 years 10 months before #15567 by manual-mecanica
Manual-Mecanica Answer on the Re: Urgent Help Kia Sportage 2000
The canister if it was very important friend this tends to drown the vehicles because it generates a low precion or high precion that contradicts which the pump nesecita and tends to generate a low or high precion in the pond.
14 years 10 months before #15585 by manual-mecanica
I tell you today I went to change the spark plugs and it turns out that these were covered with a coffee tartar, according to the mechanic they were already bad, I changed them for a new game of Iridium spark plugs, spend like $ 50, for everything to see how it goes.
I made them reviewed the main relay of the gasoline pump, I decided that it was best to change the 30A main relay, and the other 15A fus Fuse but 20A, I don't know if this change of fuses can affect something, tell me ???
With the Main Relay of the injection pump, for the moments it does not have the distribution of Kia, for two weeks, so the mechanic bought one of 30a, with the same configuration of pins of the original, but in the part of the relay says Ford, I do not know if it is fine, if it will work well, I do the prubeas with this relay?
I would thank you for your comments ..
14 years 10 months before #15586 by manual-mecanica
I understand, what do I tell the mechanic to disconnect it, although when I put the Scaner, it does not mark any error related to the calister?
14 years 10 months before #15587 by manual-mecanica
14 years 10 months before #15588 by manual-mecanica
back side of Ford's relay placed in my kia, it will work well, turn on the car and start well, without any problem
