Urgent Help Kia Sportage 2000
14 years 10 months before #15622 by manual-mecanica
Manual-Mecanica Answer on the Re: Urgent Help Kia Sportage 2000
I tell you, today I went out to try the car, I ran it like 20kms, and all good, but I have been lit the light of the snapper, I do not know if this will have to do with the REL Could this be?
14 years 10 months before #15629 by manual-mecanica
That is a land problem in the electronic part when you have bad land that happens, it is the same as I told you before, a bad land after a while begins to burn components.
14 years 10 months before #15632 by manual-mecanica
Friend, thank you for your comments, I have been very useful, I wanted more help, unfortunately in my country there are no very good electrical mechanics that we say, and those who are regular charge they charge you
could help me with one diagram that cables need to be to the ground, in which part of the motorcycles should be these, as well as those of the gasoline pump, not presisted to do it, but at least it will tell me what the mechanic is or less than what you are talking about.
I would very much appreciate your help, since I need to take it to the morning mechanic, to prevent something more serious from passing.
14 years 9 months before #15686 by manual-mecanica
All electric connectors of the cars or almost everyone really have a cable either black that indicates mass, this cable can find it with a test or a test lamp you find it and put it to chassis with any bolt and you already have good lands, squema of that vehicle I do not have but with that data anyone with a basic electricity nosion can do it. Good luck greetings and an abraso.
14 years 9 months before #15699 by manual-mecanica
I tell you, today I went to the mechanic to change the oil of the automatic box of my kia, it turns out that the oil was totally bad, and the box was starting to be dancing, luckily it was still on time, I also changed the automatic box filter
I also decided to change the air filter and my surprise was enough to see the state of the previous filter, totally dirty and obstructed, I attach some photos, what they think. ??
