Little power Kia Sportage 2001
14 years 11 months before #15442 by manual-mecanica
Little power Kia Sportage 2001 published by Manual-Mecanica
Greetings I am from Quito Ecuador, I have a 2001 Kia Sportage and unfortunately a couple of months ago I feel that it has lost power, in the climbs I must go first because the car does not go up !! And when you start you feel vague !!! Can it be for the type of gasoline that I place? or the spark plugs? the oil ?? I ask you to help me with advice to gain power, what should I do ??? thank you!!!!
14 years 11 months before #15459 by manual-mecanica
Manual-Mecanica Response on the Re: Little power Kia Sportage 2001
mmmm. I would like you to contribute a little more data, for example if you throw smoke and what color, if you don't get very hot in some occasion, when you did the complete tuning, what problems you have when starting, now to start solving the problem you can start by checking the pastes to your clutch in some countries is clutch, luck and pass us more information.
14 years 11 months before #15485 by manual-mecanica
Thank you, I made the motor ABC 5000km the car not made blue smoke, the engine is fine, the spark plugs burn well the doubt I have is what type of spark plugs are optimal for this type of car and if I can do something additional so that it has a little more strength the engine, maybe the oil has to do? And with respect to the clutch the problems are fine when starting are that it is vague and rattle a little, it has no strength
greetings
14 years 11 months before #15486 by manual-mecanica
Hello Alejandro, I want to chat with you and talk about what happens to your car, and if you resolved it?
Greetings,
Robinsanc@hotmail.com
Add me to your msn
14 years 11 months before #15503 by manual-mecanica
You want your Catalitical is obstructed if you don't have it or on straight or up.
