Hyundai Accent 2001 1.5cc
14 years 9 months before #16210 by manual-mecanica
Hyundai Accent 2001 1.5cc published by Manual-Mecanica
The problem I have is that when I take the chola in half the car drown me, I have cleaned the injectors, the TPS, the gasoline pump is new and I don't know what to do. If there is someone who can help me, I thank you please.
14 years 9 months before #16264 by manual-mecanica
Manual-Mecanica Response on the Re: Hyundai Accent 2001 1.5cc
Change the gas filter is covered and reduced the passage of gasoline and that makes the car drown >>>>>>>>
14 years 9 months before #16267 by manual-mecanica
hi how are things.
First of all it is very difficult to decipher that it may be causing you. I would like to know what the chola is halfway?
I don't understand very well. I would like you to tell me that if your engine is 12 valves or not? And if you can give me the motor number. Another question your vehicle has "Check Engine" light and if you have it, get on?
I await an answer ...
14 years 9 months before #16295 by manual-mecanica
The chola is the accelerator pedal and when I take it in half it is when the engine is drowning and if it is 12 valve and 1500cc and has no check Engine
14 years 9 months before #16296 by manual-mecanica
I have not changed it, I'm going to try to see thanks friend
