Well, if you have a scam, look at the air flow in this one has to be + or - in 1.8 v in vel. I slow down, if you have bosiloscope, look at the signal if it is not cut when you accelerate. If you can very carefully carefully the sensor with a soft solvent porke if you do not damage look to see Sieste has no dirt in the elfilamentob ke brings I hope this helps you this.
