Problems with Tacomethater and Velocimeter
14 years 7 months before #17242 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Tacometer and Velocimeter
The velocimetro goes in the gearbox in the differential exit to the palieres.I the tacometro should go in the wheel of inertia.deberia of having a sensor that serves even ael on the car and also to measure the RPM of the vehicle .... I also recommend that you check the box since the failure is of the 2 and not one of one of one of one
14 years 3 months before #20140 by manual-mecanica
Hello, I have a vw jetta 96 and the same thing happens to me when I turn off the car and I ecimette and the tacometer begin to flash both 0
the other day after reviewing connections I got another board of a VW Jetta 98 ​​and when I install it, I will work everything to perfect perfect
13 years 7 months before #28416 by manual-mecanica
Hello friend, I have the same problem, with a Mitsubishi Lancer 1998, when I turn on the car the tacometro works but when I run about 30 minutes it goes out, just like when the car is parked for a long time to the sun the same thing happens ... you have not found the solution to this problem that may be? greetings....
13 years 7 months before #28481 by manual-mecanica
Czech friend The ground connections by anade
12 years 9 months before #37456 by manual-mecanica
Friends ... I have the same problem in my lancer, hopefully someone has the precise solution ...
thanks
