Dear sir, the first thing q. You must check that you have voltage and negative feeding in the BBA. From gasoline if you have feeding, check the pump, otherwise bouncing with fusibles, relay this must have food, in a direct battery pin, the other with contact, the other is emvia the computer is a negative the other is the one that is the one that emvies the voltage to the bba. You must submit everything more the wiring, I hope it helps you, greetings and luck.
