Citroen C15
14 years 1 month before - 14 years 3 weeks before #22064 by manual-mecanica
Citroen C15 posted by Manual-Mecanica
I have a problem with a Citroen C15 Bencinero, the 8 valves were changed, the complete guide seats etc. Rod, axial and rings metals were changed, the TPS, distributor lid, ignition, rotor, cables and spark plug Please if you can help me, you appreciate
Latest edition: 14 years 3 weeks earlier by .
14 years 1 month before #22067 by manual-mecanica
Manual-Mecanica Response on the Re: Code P0171
It sounds like a fault in the TPS sensor or acceleration sensor, or can the injection of the vehicle have bad, in what you should clean injectors or better change them, by the way, what year is it? Commonly the square silvery of the 90s had carburetor and it was very easy to regulate the mixture, and it may be that the problem lies that you should carbure it.
I hope it serves you:)
14 years 1 month before #22073 by manual-mecanica
Look for the power sensor is located in admission carries four cables and is subject with a screw that is your problems
14 years 1 month before #22074 by manual-mecanica
Manual-Mecanica Answer on the Re: Code P0730
I have problems with a 4T65e Impala Box 2001 I scan it and I throw the following codes.p0730, P1187, YP1189 They can proclaim me in these faults I thank you.
14 years 1 month before #22078 by manual-mecanica
P0730, P1187, YP1189 Transmission ...
P0730 INCORRECT GEAR RAT
P1187 O2
SENSOR HEATER CONTROL CIRCIT I hope it serves you:)
