Citroen C15
14 years 1 month before #22082 by manual-mecanica
Manual-Mecanica Response on the Re: Code P0171
If you already tried the fuel pressure that must be between 52 psi to 59 psi, most likely the MAF is not working correctly, you would suggest you try another since it can cause a poor mixture in certain moments
greetings
