Nissan P1610 and P16FF fault codes
13 years 9 months before #25785 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan P1610 and P16FF fault codes
: Ohmy: how many visits and no thanks ...
and they should answer as my friend Wacharo if they served them or not and did to solve their problem friends ...
13 years 9 months before #26241 by manual-mecanica
Excuse me for not answering before but already checked everything you mentioned and nothing brought it from the United States and no other than doing
your help in advance
13 years 8 months before #27106 by manual-mecanica
First Hello everyone, I have a similar problem but this was occasionally occasionally installing a satellite tracking system to a 2005 Nissan Patrol 2005 now the code remains active and I cannot erase it with the Scaner, what can I do, in advance thank you very much.
13 years 8 months before #27171 by manual-mecanica
Thanks, those tips are very helpful. I have not had this problem even but it is very helpful to know to be prepared.
13 years 3 weeks before #35028 by manual-mecanica
Jesus_06 wrote: The P1610 code is because of a problem with the NATs, or better known as the vehicle immobilizer system. And this arose for the following:
-To are using a key that is not registered or does not transmit the code
- BCM or ECM are bad
and therefore now it is in "Blocked mode"
you can do something fast:
1. Confirm the code that throws
2. Exit the blocked mode. If it is the P1610 code, follow the following with a copy of the vehicle key:
(1) -Colocate the Switch in off
(2) -Coloca the switch on ON with the registered key (not start the engine). Wait for 5 seconds
(3)-Switch says to the position OFF. Wait for 5 seconds
(4) -Repeir Step 2 and 3 twice more (being a total of 3 times)
(5) -Anca the engine
tries with this and writes to us if T worked. If not, there will be a detail with the diagnosis checking diagrams and other things.
The other code does not exist or does not comply with the structure of a code
if you want to pass the diagrams of the immobilizer system just let me know, anything only writes and try to help you friend you
Hello, apologize for reliving the subject but I have a similar problem with a Nissan, it gives me the P1610, P1620 and P1626 codes and I do not know if you could facilitate the immobilizer diagrams to be able to review them, it would be very helpful.
Greetings and thanks in advance.
