Peugeot 406 does not start
12 years 1 week before - 12 years 1 week before #42177 by manual-mecanica
Manual-Mecanica response Peugeot 406 subject
Well Carloos I don't know what engine type will you have 406 but here I attach a scheme of 406 ..
Anything you let me know ... if you cannot open it or if it is not the same model
or
Latest edition: 12 years 1 week before by .
12 years 1 week before #42178 by manual-mecanica
The Peugeot has 2.2 16v gasoline engine that had your car ???
12 years 1 week before #42179 by manual-mecanica
I can't open it to the file and the car has a 2.2 16v engine if you could send it to me another you would appreciate
12 years 1 week before #42193 by manual-mecanica
If everything is ok and you say that you have a sign in the injectors then the drama or are the injectors themselves or the fuel pump that does not send, if I read me again to tell me the fault to have that we can do
12 years 1 week before #42197 by manual-mecanica
Hello, if everything is OK has injection time and take out the injectors and send the fuel sprayed by normally ignition order that does not have are pulses in the ignition coil so it does not start. I already check the cables the coil and everything walks but the pulses for the coil do not leave the ECU directly and already puce a new ECU and with both of them it does the same for that reason no longer I know what the most check because everything is fine how only it is not if this car when it is immobilisal short only the spark ???
