Peugeot 406 does not start
12 years 1 week before #42198 by manual-mecanica
Manual-Mecanica response Peugeot 406 subject
Hello if you have a fuel injection pulse tested with testing the PMS captor? It usually happens that having an anomaly or a metal chip varies the signal of the captor and does not generate ignition pulse to the coils .. I hope it will help you ,,,
12 years 1 week before #42199 by manual-mecanica
Hello, I already checked it and before the doubt they shy it as 15 times and everything is normal to check everything that could be checked from cables to sensors. Buy a new ECU to try the BSI or BSM and all normal try the coil and all its cables and chips. They codified the key and nothing is still dead
