Lanos 1.6 Problems (Daewoo)
13 years 1 week before #35578 by manual-mecanica
Lanos 1.6 (Daewoo) problems published by Manual-Mecanica
Good firstly I would like to help me, the problem is that when I accelerate the car (Pata thoroughly) begins to expel white smoke due to the exhaust and then mostly a spark plug burns, another thing I have noticed is that the acceleration body is filled with oil. I hope someone can explain why this happens and how to solve it. Oh I forgot to say that I just did the engine and repaired the camera, for doubts I went down again to inspect the camera and all good.
13 years 1 week before #35579 by manual-mecanica
Manual-Mecanica Answer on the Re: Lanos 1.6 Problems (Daewoo)
Good evening I tell you that they are the gums of the valves if you are riding the Sabo Buscala brand it has to be 5.5 or 6 in the cylinder that is wetting the spark plug and logical having oil in the cylinders must smoke
13 years 1 week before #35580 by manual-mecanica
Of course it should be noted that you have not mounted the front rings on that piston or you have left it very open, let me know
13 years 1 week before #35581 by manual-mecanica
Brother already lowered the camera again to see what happened, suspected of the gums, but these were perfect .. that's why my confusion .. I don't know but it gives me how to think about the (cts) I don't know what you tell me about it ..
13 years 1 week before #35584 by manual-mecanica
The white smoke is water in the camera if this is the problem the water level of the radiator to decrease without having lost abroad, look at the water, if this is the case then you have problems with your cylinder head or packaging of it, the Daewood are commanded to have to have problems with the butts.
