Lanos 1.6 Problems (Daewoo)
13 years 1 day before #35811 by manual-mecanica
Manual-Mecanica Answer on the Re: Lanos 1.6 Problems (Daewoo)
Check the injectors are opening a lot or are direct
13 years 20 hours before #35817 by manual-mecanica
Good I tell you that you disconnect the hose that goes from the acceleration body to the camera cover, and it has not ejected smoke again, I consider that it is the air filter, which I have not proven yet, I do not know what you say? When I bought it, I connect the hose again and tell you to see what happened, ..
13 years 17 hours before #35819 by manual-mecanica
Friend usually expels smoke by. problems with hoops anyway. Control the viscosity of the oil.
