Difficult ignition in Nissan B13
12 years 11 months before #36229 by manual-mecanica
Difficult on Nissan B13 published by Manual-Mecanica
I have a problem with a Nissan B13 Ga16de engine.
To turn it on, you have to step on the accelerator, in addition once on when trying to accelerate it drown. Some indication of failure. The check Engine witness is not on.
Greetings
12 years 11 months before #36249 by manual-mecanica
Manual-Mecanica Response on the Re: difficult on Nissan B13
Look for what I understand could be dirty the acceleration body opened to clean it manually
12 years 11 months before #36252 by manual-mecanica
Now he ignites the first, without any problem, he stays in progress, but the very unstable slowdown and also the engine sounds as if it were diesel, draw the spark plugs, all hollin covered, which tells me that the mixture is too rich. I think that if it was badly synchronized, simply not part or cost him. Well this engine has a lot of mileage because it was public transport. The MAF or FLUJOMETER shows that the IAC_AAC valve was also intervened, it lacks a spring. Will continue.
12 years 11 months before #36256 by manual-mecanica
Look try to search or give you an IAC valve in good condition and with all components there may be this problem and also sees the butterfly
12 years 11 months before #36258 by manual-mecanica
That engine starts even with a tooth of the chain that is run, I tell you for it already happened with the vehicle of a customer who had the hydraulic tensioners, bad sounded ugly was ugly and did not accelerate well. Verify valvular time.
