Change the oil winged box
12 years 10 months before #36979 by manual-mecanica
CHANGE THE CASE AILA PUBLISHED BY MANUAL-MECANICA
CHANGE THE BOX AL OIL BUT THE ALANTE CAP
12 years 10 months before #36997 by manual-mecanica
Manual-Mecanica response on the subject Change the oil box
If I remember correctly in the megane that screw weapon inside the selector like the Volkswagen if I do not remember it, take someone to repair boxes because we talk about the mechanical box truth?
12 years 10 months before #37004 by manual-mecanica
No friend the box is automatic now it does this when I turn it on the car applies but weak and it becomes neutral it will be ekl type of oil that made it was D3 PDV I am Venezuelan or it can be covered filter or graduation that will be
12 years 10 months before #37009 by manual-mecanica
It is clearer to ok if it can be the type of oil and it can also be or affect the covered filter, but before changing the oil the car moves or not? Because if so, the type of oil may not have very little or does not correspond
12 years 10 months before #37018 by manual-mecanica
Friend bought the Merco 4 that is the same inside 4 and the car is still the same and if the car was rolling everything well the question is when they took that tampon that grabs the selector according to that is fine but that body of the valve carries some graduation that there it lost wing wing to him 3 liters
