Nissan 2.4 16V oxygen sensor failure
12 years 9 months before #37382 by manual-mecanica
Manual-Mecanica Response on the subject in Nissan 2.4 16V oxygen sensor
Aver to fix the lambda shadow sensor you must check it with an analog octophast or multimeter, now if it is a temperature problem you will realize easy, take out your spark plugs if you see that they are reddish stockings it is because you have excess temperature is by the color.
