Problems with Orion 1.6 Ijection System
12 years 8 months before #38337 by manual-mecanica
Problems with Orion 1.6 ijection system published by Manual-Mecanica
Hello, I have a 1996 Model Ford Orion has injection carbure and does not send a gasoline when the curtain opens the pump comes to the injector and try everything and nothing begins when it started and then it was getting worse and now it does not pull anything of gasoline already changes the injector but follow the problem of now thank you very much
12 years 8 months before #38355 by manual-mecanica
Manual-Mecanica Response on the topic Problems with Orion 1.6 ijection system
Czech if the injector has a pulse at the time of starting to rule
12 years 8 months before #38364 by manual-mecanica
Hi Kikemec if there I notic
12 years 7 months before #38552 by manual-mecanica
I continue with the problem rejection I want to kill it left and now I began to fail again :/
12 years 7 months before #38568 by manual-mecanica
He took alone and then came back or did something
