Problems with Orion 1.6 Ijection System
12 years 7 months before #38610 by manual-mecanica
Manual-Mecanica Response on the topic Problems with Orion 1.6 ijection system
Have you check the filter? Lastly you will have to verify the injector signal while it works and see that it is not a signal problem. Have you tried to connect the Scaner to see if it gives you a fault diagnosis?
12 years 7 months before #38612 by manual-mecanica
Hi Daniel if I already found the fault stops sending the pump so that whenever check everything I work now that I do not arrive I am looking for the problem I have the entire elactric site of the fuse functioning well and the relay already changed it now I will resole
12 years 7 months before #38638 by manual-mecanica
If that is why he sends direct current to the pump to try the work, if he does not cut, no drama could be a earth problem also if the relay sounds strange and the pump is cut.
12 years 7 months before #38706 by manual-mecanica
Thank you all the problem of the two problems in Kikemec. Thank you, it was a land problem and the return and the other problem that melted the contactor card was made. in helping
12 years 7 months before #38727 by manual-mecanica
You're welcome for that we are, luck and greetings.
