Fiat Punto SX 60
12 years 2 months before #41037 by manual-mecanica
Fiat Punto SX 60 posted by Manual-Mecanica
Hello to everyone. This is my first day in this forum. I have some mechanical problems with a fiat point 60 sx of 95 and I hope someone can help me. A few days when putting the hand brake made a strange noise and notic how it was clear. The case is that since that day I notice as if the car was slow I know if that will make the car stay at all.
12 years 2 months before #41038 by manual-mecanica
Manual-Mecanica Response Fiat Punto SX 60 theme
On the gear lever you have a back switch, change it, it is usually white.
You have moved the brake adjusters of the rear drums, open the rear brake drums and you will see that some dock or the adjuster are bad.
12 years 2 months before #41041 by manual-mecanica
Thank you very much Igryo, tomorrow I put myself with it. I will tell you the result.
12 years 2 months before #41049 by manual-mecanica
Hello again to all. Today I have been disrupting with the problems of my fiat point 60 sx. To that sensor?, He left it. My other problem was with the handbrake, when disassembling the lid of the brake lever, the first thing I realize is there are two cables, I suppose that one for each wheel, and that when the brake is activated, the two cables do not tense in parallel. If you can tell me something. Thank you all.
12 years 2 months before #41058 by manual-mecanica
First caravan the groove back is in the gearbox, before changing anything, disconnect it and you have a bridge with a connector and see if the lights turn on, eye the contact has to be open, if you turn on, the bulb changes and already, there is no more tests if you do not turn on the cable, the bridge on the connector does not Complete system that ever but ever is more, now it is normal for a cable to be more tensioned than the other because that is regulated in the wheels and the wear of balatas will depend on singing more turn a wheel than the other, that normal in all the cars, the regulation is interior but only for the length of the hand brake, if you pass and squeeze a lot if it will be brake of the vehicle.
