Fiat Punto SX 60
12 years 2 months before - 12 years 2 months before #41061 by manual-mecanica
Manual-Mecanica Response Fiat Punto SX 60 theme
Thank you very much Kikemec. I will follow your advice. A question, when you say bulb you mean the sensor that goes to the gearbox, no? And the bridge in the connector does it by entering one end of a cable in a hole of the connector and the other end in the other hole, right?
Latest edition: 12 years 2 months before by .
12 years 2 months before #41080 by manual-mecanica
Hello Kikemec. Thank you very much for your advice, the bridge resolved my question, it works, I just have to change the sensor. As for the brakes I have not yet been able to check it. Thank you very much
12 years 2 months before #41125 by manual-mecanica
Sorry I told you on the gear lever, that I would be thinking:) and I am a mechanic and a few years ha ha, I see that they already gave you solve, luck. You tell us.
12 years 2 months before #41126 by manual-mecanica
Thank you very much, I have already managed to solve it. Now I have another problem, I have changed the back sensor and occasionally, when I turn on the contact, the temperature needle shoots to the top and stays like this. Then after being running for a while and after turning off the car, when it starts it again it falls down (cold). Perfectly, I don't know how to solve it.
