VW Eurovan 2.5 truck does not turn on
11 years 9 months before #43532 by manual-mecanica
Manual-Mecanica response on the VW Eurovan 2.5 truck theme does not turn on
Mmmmmmm that weird, but if you moved the cables and worked well and then installed and did not work, then you must continue there you are well aimed in the Czech search again by moving the cables and samarria the computer you want a pin does not make good contact.
