Hi Kikemec, if it is weird, from there the consultation, the pump axis has 17mm diameter on a retain side, with its key and conic, I have seen cracked corades on the injector side in a Berlingo, the thing is not that before breaking the axis, the crankshaft rotates only moved by Mot. Starting, to which he changes sound and already ... begins to hit, I repeat, it is as if he started first to chop and start from there and change, stops to try to tear it out and check that again 6 teeth more than 6 teeth more ... Luckily they have not touched the valves! .It is a pod that brings me crazy !!! The belt is fine, it is not a matter of stopping the pump, I think that for the moment of injection or I already know !!! Thank you for your interest, from these failures is where you learn
