Signal intermittent signal does not work Ford F
11 years 7 months before #44115 by manual-mecanica
Signal signs of flashing does not work Ford F published by Manual-Mecanica
Good morning, I need to know which device emits the acoustic signal of the flashing and where it is located, since it does not work. The car is a Ford Focus 100-CV 1.8 TDCI Guide of January 2004. See if you can help me, thank you.
11 years 7 months before #44121 by manual-mecanica
Manual-Mecanica response on the subject acoustic signal of intermittent does not work Ford F
Having the intermittent accusic signal should not have you refer to the slight tic-tac that usually sounds.
It is a relay is under the steering wheel has 3 pins and you will have 4.
They usually carry in the terminals some drawings of (r, -, 15 or 30).
11 years 7 months before #44122 by manual-mecanica
Thank you for answering "Igryo". I was indeed referred to the classic Tic-Tac that the intermittent do. Is it easy to disassemble and replace?
11 years 6 months before #44131 by manual-mecanica
If it is easy to replace but you do not buy it as a relay, it is requested as Haazzar's flash, but I have a question if this bad one does not have flashing and yours works or do I get equibo?
11 years 6 months before #44136 by manual-mecanica
The flashing works perfectly, both in the painting, and on the outside, what does not sound is the classic warning tic-tac. The problem is now but I have understood bad "kikemec" as you tell me, it is that if the flash does not work, the flashing lights should not work, if so, where could the failure be?
