Hi Wal7er, from your second post "hahaha I do not get out of another because I get pure cachs hahaha the cars cooperate, others no, andx are your friend Kikemec. Ultimate diagnosis of Salfasur is to remove butt, the owner was almost infarcted. He had not read well, but with 35,000 km the piston head should not be perfectly clean, free of carbon.If it is completely decarbonized and the rest of the cameras have the "normal" carbon for 35000, the problem is clear, it passes cooling from the engine to the camera (generally packaging defect). If you consume refrigerant and do not boot it, it passes to the camera, decarbonizing and incidentally producing missing in that cylinder. Is there info about previous temperature problems? Was the car new buyer?
In any case, what I do for the diagnosis of that problem is: leaving the valves of that closed cylinder or in compression, locking the crankshaft (an danger if it is not done well) and introducing compressed air through the spark plug hole, if there is communication between the refrigerant cameras and combustion cameras at the time that the level of the refrigerant of the radiator or glass of the radiator expansion upload, if there is no variation is not that. After all, it may be that the preliminary diagnosis of the consent can be correct. greetings.
