Hello Wal7er, checking the picture then realized that they were current data. With the heating engine (48 c), idling, operating in Cl (Close Loop), I bone decrease loop. The fuel correction parameters respect the signal of the O2 Sensor show a slightly rich condition here all more or less ok considering that at least one or more cylinders there is a more cylinder Combustion The only thing that seems strange to me is the load value calculated approx 4.7 %, quite low considering that the engine, according to what you say is operating in three cylinders. The other is the advance to the ignition 1.5 degrees TB quite low. EVISARCONECTIONS TO THE ECU MOTOR Especially the masses, check connections to the MAP, possible leaks in the multiple of admission with emphasis on cylinder 2, and if you do not have access to Freeze Frame, Misfire Counters an oscillogram of the CKP and CMP could give you some clue and step to see the synchronization between the two (corecta synchronization of the distribution). Well, the ones that happens is that several years ago, in a very similar system a similar problem that could never detect, obviously in that time I handled less info and experience, I am interested in knowing what happens in that chub, in any case they are in these difficult cases where you learn the most and that is the idea. kind regards
