Citroen C3 does not start
11 years 6 months before - 11 years 5 months before #44525 by manual-mecanica
Manual-Mecanica response on the Citroen C3 topic does not start
greetings
Last edition: 11 years 5 months before by .
11 years 5 months before #44558 by manual-mecanica
It is already solved, I was leelly a tutorial in another Citroen straw and its failures.
The problem is that in the fuse box of the motor compartment you can see fuses but that is not everything you have to take it out and open it and inside it carries a plaque printed with relays.
Those relays carry the windshield clean the pneumatic pressure sensor and for what I see they fail and much.
11 years 5 months before #44562 by manual-mecanica
Hi Igryo, then, was it the injection system?
11 years 5 months before #44568 by manual-mecanica
[IMG = http: //imagizer.imageShack.us/v2/150x100q90/c/707/ohpj.jpg] [/IMG]
In this case the injection goes through another relay. There are about 20 or more all soldiers.
11 years 5 months before #44569 by manual-mecanica
[IMG
Let's see if the image comes out
