Citroen C3 does not start
11 years 6 months before #44484 by manual-mecanica
Manual-Mecanica response on the Citroen C3 topic does not start
Hello again, it measures the resistance of the collector, do not weigh only the signal, but also of the voltage that sends (terminal 1 and 2, from 425 to 525 ohms, moving the cable to rule Apart from the injection relief can be bad, and it does not feed neither bomb nor coils .. Go see, luck !!
11 years 6 months before #44488 by manual-mecanica
Looking at a manual, in the Sagem coil, it says primary resistance 0.55+-0.05 OHMS, and also, which in this carries the camshaft collector (important to start) incorporated. I don't know if he carries the same type of coil as yours, but in case he served you
11 years 6 months before - 11 years 5 months before #44492 by manual-mecanica
hello
Last edition: 11 years 5 months before by .
11 years 6 months before #44507 by manual-mecanica
Let's see is clear that nobody knows everything and if they tell me that the Canbus system carries braided cable to .....
what do you want to think when I see a braided cable in a semi -new car ???
What I want to get to. There are better ways to explicate something without reaching mockery and correcting writing seems very ugly.
Thank you for trying to help me Fiat147 and Ismael53, I close the subject. When you know that it happens to the car I already commented.
11 years 6 months before - 11 years 5 months before #44509 by manual-mecanica
.Saludos cordials and happy fists.
