Hello, thank you very much, after starting it works very well, it does not lose strength, a little smoke comes out by exceeding 2500rpm but they are the valve seals, the problem every time was increasing more, the witness goes out like the 5 seconds of giving contact and the spark plugs are still fed by about 20 seconds, what happens is that if I give contact only once and I hope that the witness is shifted. Almost impossible to start, on the other hand, if I give contact, I wait for 10, I close and open contact immediately, I do this about 6 searches in a row, the truck starts immediately, if it has a temperature sensor but if it was defective, it would be fell as the check would turn on the check or not? Thanks for the help !!!
