Hello everyone, Diego; I was something important to me that is to check the status of the ground connections, from the engine to the chassis, and the negative engine of Ba
Teriay the same negative battery terminal (which does not find sulfatation). With the negative of the Tester to battery mass it measures the voltage that exists to the chassis and motor, I do not know if you understand me, the teencia drop values must be small, generally low 0.15 V of fallen from dough tension is considered a good connection. Greetings
