Luz Stop Jeep Grand Cherokee 1997 does not turn on
11 years 3 months before #45810 by manual-mecanica
Manual-Mecanica Response on the topic Stop Jeep Grand Cherokee 1997 does not turn
Look, I don't know if it will be your case but there are French vehicles equipped with a unit called BCI that commands the entire electrical system and fails that way but I am not sure if it brings it is like a small computer with a Czech black color if it exists because if that is the problem, if you already check everything and it is fine
11 years 3 months before #45820 by manual-mecanica
Hi Kikimec The sensor you mention where the only thing I found could be located was a sensor that is down the back seat and has an arrow that works with the speed sensors to activate the brakes and have the acronym CAB and has an arrow that must point to the front of the vehicle otherwise it will not work will be the sensor you mean ?????? Thank you beforehand.
11 years 3 months before #45825 by manual-mecanica
In case you despair, I will give my opinion of what I would do: take out a positive cable, from the battery, I would put a fuse (with its box) take it to the pedal switch, from there it would come out with another cable to the rear headlights and there "eliminate" the positive of the harness (eye, first difference which is that of the brake light) and "holy Easter" that is said ...
11 years 3 months before #45830 by manual-mecanica
Pucha is that in your model I have not seen it where it is going, I have a client with that Cherokee I will call it to do and be able to check before you equibo and kill the abs hahaha
I tell you if it comes to me, in any case you can wire again it is easier to do the installation hahahaha
