I am half lost, there are position lights that is the one that breaks the first turn, with this turn it lights the light plate lights and reds of the major focus, but that are not the brake, if it does not turn on the brake, and Czechs the current and everything is fine until the sole is then the blister if there is no current signal then checks the fuse, these can be inside the vehicle or in the motor They put on both sides, if you are all fine you look at the pedal you take it out and make a bridge in their connector to check whether it turns on or not, that is, remember the bulb button the bulb the light is off, if you do not press it, they have to turn on, in another term, open continuity and close continuity, if by magic none of this would be wiring If any brake light turned out to be easier and you connect again from that cable that works, only the signal or positive as you want to call it, the lands always have to be new, it is a cable that goes to any bolt that makes mass. If it is not clear to send us a photo of which are the lights that turn on and which no, luck
