- Thanks received: 1
06-19-2025 Hits: 680 Technology
Kikemec wrote: Look ahy you touch a topic that in general is like a discussion, there are those who believe that a car with a bad regulation of valves is heated, but I do not believe in that part, because there is no relationship, between one and the other, there you say that the little time of overlap between the admission valve and the escape valve, would produce an increase in temperature, but it is very little caused since the refrigeration of the refrigeration of the refrigeration of The engine is done by water and oil, now, an engine that works required by a bad valve regulation could generate a temperature increase if the exhaust gases generate a contribution in the engine but it would not be of such importance to heat the engine, since the opening time would not be so significant.
