Chevy that throws water
11 years 3 months before #45890 by manual-mecanica
Manual-Mecanica Answer on the Chevy theme that pulls water
But from what you say, the vehicle is not heated, I already remain clear about the pulmon
11 years 3 months before #45895 by manual-mecanica
Thanks if the plug was wrong. But I still have the doubt of whether the babbles that do not seal well can try heating or only ace that has the engine?
11 years 3 months before #45896 by manual-mecanica
scheme the heating could be but only if water comes out and you heat up due to lack of this, a hot engine does not work well will be irregular by the temperature deltas.
11 years 3 months before #45898 by manual-mecanica
Forgive toes but if it would not throw water, it did not have anything broken abandoned or passing water only bad comprehension through the valves would he warm? or only the engine would fail
11 years 3 months before #45902 by manual-mecanica
Look ahy you touch a topic that is generally like a discussion, there are those who believe that a car with a bad regulation of valves is heated, but I do not believe in that part, because there is no relationship, between one and the other, who says that the little time of overlap between the admission valve and the exhaust valve, would produce an increase in temperature, but it is very little reasons. Nothing more, now an engine that works required by a bad regulation of valves could generate an increase in temperature if the exhaust gases would generate a contribution in the engine but would not be of such importance to heat the engine, since the opening time would not be so significant.
