The oil pressure sensor is turned on
12 years 1 day before #42262 by manual-mecanica
Manual-Mecanica response on the Re: the oil pressure sensor is turned on
First of all you must check two things, one is the engine level in the engine and another is that you check the oil pressure bulb or change it to be sure and you can continue with the pump
